Archived from groups: comp.sys.laptops (More info?)
I've been using a Netgear WG511 wireless adapter in my laptop for about 6
months now with no problems.
All of a sudden, the adapters's LED's do not light and I have no wireless
functionality. I tried a replacement adapter and that one still doesn't
work.
Is this definitely a hardware problem w/ my slot, or could it be a
bios/driver/software issue? I don't recall installing any new software in a
while.
A very long time ago I tried to install win98se on a 3110ct and the
pcmcia slot did not work. I asked the group for drivers or a patch,
but was told that the 3110 was built for win95 and NT. I then
installed XP Pro and the pcmcia port worked with no problem. Maybe
the drivers you used are corrupted.
"Danno" <djdlashnospam@comcast.net> wrote in message news:<qamdnSrebuaiezXdRVn-gg@comcast.com>...
> work.
> while.
> Any help is greatly appreciated.
> PC: Toshiba Portege 3110ct
> OS: Windows 98
> Adapter: Netgear WG511 wireless card.
In the BIOS you can switch the PC Card slot between Cardbus, PCIC and
Autoselect. I'm not sure what the implications are, although in
general, I think you need PCIC for the CD adapter, and Cardbus for a
PCMCIA Card. Autoselect may work with some OS, but I have had problems
with it with Win2000.
HTH
Vaughan
news:qamdnSrebuaiezXdRVn-gg@comcast.com...
about 6
wireless
doesn't
> work.
software in a
> while.
> OS: Windows 98
