Hi,
I'm having an issue with SSD cachine (aka Intel Smart Response) with my Z68 chipset mobo. Specifically, once I built my system (specs listed below) I enabled SSD caching through the Intel Rapid Storage Technology software (not by hitting CTRL-I during system boot). Everything was working great for a couple of weeks. Then, I decided to disable the caching so I could try to see if there was any perceived difference in system performance. After disabling the caching and rebooting, my system would not boot up. I had to throw in the Windows 7 DVD and do a Repair in order to get my system up. Now, if I go into Intel Rapid Storage Technology, it still thinks that I have SSd caching enabled, but tells me the accelerated volume is not available and therefore caching is not functioning properly. It gives an option to disassociate the SSD drive from the accelerated volume, but taking that option causes an error message saying that the operation can't be performed. Also, when the system is booting up and Intel RST shows the status of my drivers, it lists the SSD drive as "Disabled" and won't allow me to do anything with it. I have tried removing the SSD drive and rebooting, reinstalling Intel RST, and flashing my mobo BIOS, but nothing seems to allow me to get the system into a state were it doesn't think that SSD drive is already in use as a caching disk for an unavailable volume. Can anyone suggest a fix for this? I'd prefer to avoid a re-install of my OS if at all possible. Any ideas? Here's my system:
Mobo: ASUS P8Z68-V Pro, BIOS version 0501
CPU: i7-2600K
RAM: G. Skill Ripjaw PC-12800 (2 x 4GB) DDR3-1600
GPU: EVGA GTX 560 Ti
SSD: 64GB Crucial M4
HDD: 2 x 1TB WD Caviar Blacks 64MB cache in RAID0
I have the SATA drives set to RAID (not AHCI) in Bios, and I'm using Intel RST version 10.5.0.1026.
CPU: i7-2600K
