Okay well I bought ram it's rated at something like 1600 but my motherboard is only recognizing it at 1300. How do I change it?
mobo
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128397
ram
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820211409
P.s. One of the comments on the motherboard was;
mobo
ram
Cons: This is only a Con for the beginning system builder. It requires a trip to the BIOS to correctly set up high performance ram. It was running my DDR3-1600 at 1066 out of the box and had the voltage set too low as well. Its autodetect for the ram is very conservatively and underclocked. I normally run through the BIOS on first boot, so this is not really a bad thing, but first time or inexperienced builders should be aware of it.
