A more powerful PSU can't damage the motherboard. The motherboard and other components will only use as much power as they require. The total probably is much lower than 850W.
True.
There will be no damage to your motherboard with a excessively powerful psu. But... a psu operates most efficiently in the middle of it's range. A 850 w psu will have low efficiency in your system.
Your 600w psu is fine, and you probably could do with a quality 450w unit.
