Yes No
Ads
Need Urgent Help
Forum Overclocking : General Discussion Need Urgent Help
So I recently bought a new Asus motherboard, a i5 2500K processor and corsair H80 radiator, fans and heat sink assembly. I am running an HD 5970 graphics card and a 80w corsair power supply. So after reconnecting, installing windows and downloading BF3 everything was working fine. I decided to use the ASUS built in overclock (turbo boosting) to up the processor. It frequently shut down restarted until I lost connection to the monitor. After aggravating hours disassembling and resembling I got help from someone who recommended to take out the memory and leave one. Started up, reset bios to default and commenced. Once in Windows and everything loaded back up attempting to open Catalyst and received an error. Did a system image restore and it works. But it is INCREDIBLY slow. (I have to admit while working inside I might have damaged something, either the graphics card or the mobo or both at this point) Still have yeto to do a clean install but it seems like its barely working and I'm wondering if I damaged anything.
Reply to mgroman
[quotemsg=1943159,1,1033535]So I recently bought a new Asus motherboard, a i5 2500K processor and corsair H80 radiator, fans and heat sink assembly. I am running an HD 5970 graphics card and a 80w corsair power supply. So after reconnecting, installing windows and downloading BF3 everything was working fine. I decided to use the ASUS built in overclock (turbo boosting) to up the processor. It frequently shut down restarted until I lost connection to the monitor. After aggravating hours disassembling and resembling I got help from someone who recommended to take out the memory and leave one. Started up, reset bios to default and commenced. Once in Windows and everything loaded back up attempting to open Catalyst and received an error. Did a system image restore and it works. But it is INCREDIBLY slow. (I have to admit while working inside I might have damaged something, either the graphics card or the mobo or both at this point) Still have yeto to do a clean install but it seems like its barely working and I'm wondering if I damaged anything. I am at work and can't get my mind off of this. If I need to post any or all information let me know and as soon as I go home I will post everything I can to assist. Somewhat new to diagnosing forums so unsure what needs to be done.
Reply to mgroman
the restarting may have been not enough volts, and if your machine is running slow, try a fresh install of windows (format and all) if it doesnt trouble you too much
------------------------------ AMD phenom II x4 840 3.2 GHz, 8gb ddr3 1333mhz ram, AMD radeon HD6770 1gb gddr 5, 500 watt psu, 1tb SATA hardrive... i <3 my computer
Reply to nna2
By fresh install I would boot with the disk and do it that way not reformat my hdd from windows?
Reply to mgroman
Yeah you need to boot from a disk. I am curious what would happen though if you tried to format C: from windows...
------------------------------ i7-950 @ 3.06GHz | 6GB Corsair Dominator | EVGA 131-GT-E767-TR X58 3X SLI MoBo | EVGA GTX 470 1.25GB VRAM | 4.5TB Storage | Corsair 850TX 850W
Reply to PrvtChurch
it won't let you... would be fun though huh
Reply to slhpss
:( oh well. I expected it to go about as well as trying to delete windows.
Reply to PrvtChurch
you used to be able to do fun stuff like that in the DOS days... like deltree /y c:\*.* was a great one...
Message edited by slhpss on 11-18-2011 at 08:01:06 PM
Reply to slhpss
Getting off topic due to my retardation. Okay, I tried before re-installign windows to repair it. That didnt fix the issue. I have a copy installed on the solid state and it loads fine, no problems (besides graphics card issues) and the LAN works. But on the main one, the one Im trying to get working is ridic. I cant load any of the drivers from the CD but it runs other CD's fine which is stupid and makes no sense. Also, I think my GPU is damaged. Im running the 5970 which isnt cheap and am worried its broken. The mobo is a Asus P8Z68-V Pro and everything worked fine till I started the turbo boost thing. I fragmented the solid state so that is clean and free. I ran the re-install of windows and fragmented the harddrive so no files. I guess we'll see what happens. What else would you guys like me to post?
Reply to mgroman
With the graphics card I keep getting a error in Catalyst Control Center. "Host Application has stopped working" and never starts back up. Deleted everything and tried ut given my LAN connection isnt working. Hopefully this gets fixed with a clean windows install
Reply to mgroman
Yeah it did for me. Clean install delete everything and reinstall fixes it all up
Reply to mgroman
Tom's Hardware > Forum > Overclocking > General Discussion > Need Urgent Help
There are 2159 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Does a computer NEED ram?
By Motopsychojdn, 10 hours ago:
A Pc will not function without ram, simple as, can you post the model/make of your Pc and...
Best offers
Top experts
