Hi all,
I'm planning on getting the ASROCK Extreme3 Gen3 motherboard, and I saw that it has 3 fan controllers onboard. The case I'm going to use is a COOLER MASTER HAF 912, and I'm planning on using 2x 200mm and 2x 120mm fans on the case. In light of this, should I get a 5.25" fan controller to power all of these fans or will I be okay? ALso, I plan on OCing my i5-2500k to around 4.0 Ghz, so I'm just going to use the stock heatsink, unless that's pushing it?
Thanks in advance
Thanks in advance
