which Coolermaster PSU is it?
I would recommend just getting a new PSU like Antec Earthwatts or corsair VX450
they are good quality and i think it might be enough for crossfire
P.S you should put the rest of your system specs up
If it's the Coolermaster Extreme Power Plus 390W you're talking about, it will be enough, if you don't overclock and limit the system to 1 HDD, 1 DVD-RW and a 65W CPU.
------------------------------CPU: Intel Core i7 920 @3.2Ghz, MOBO: Asus P6T SE, RAM: 3x 2gb OCZ Platinum OCZ3P1600LV6GK, GPU: Sapphire HD 5870, PSU: Corsair HX520W, HDD: Seagate ST31000528AS 1Tb 32mb, COOLER: Scythe Mugen (S775 version), CASE: Coolermaster CM690
Reply to Gulli
The recommended power usage for the 4770 is 450w. 390w might still be enough as 'gulli' said provided you have one hdd and a low wattage c.p.u., Its still pushing it..
Try this link to be sure.. http://support.asus.com/PowerSuppl [...] uage=en-us
