Sign-in / Sign-up
Solved
Motherboard power switch connector to server case
  • Asus
  • Cases
  • Power Switch
  • Motherboards
February 26, 2010 4:43:34 AM
Sorry if this is a Noob question, but I built a new i7 based system using an Asus mobo (P7P55D) that has a typical front panel connector layout (the power switch, HDD light, reset switch, etc...). Problem is that the case, an Intel server case(Intel SC5295-E), has a single cable connection for the front panel lights, HDD, Power switch- and the connections don't jive together- The single connector does slide onto the mobo pin header, but the case Reset switch acts as the power switch.
I can live with it, but does anyone know of an adapter from one architecture to another that will allow all the features to work such as the power switch, power light, reset. etc. ? Or of a way to make it work ?
I can't be the ONLY person this happened to ?
Thanks in advance,
Jim
More about : motherboard power switch connector server case
Best solution
February 27, 2010 3:21:28 AM
Hi jimp,
It is possible if you can find the parts, you would need a header like the one mounted in your mobo and the wirers with
the connectors allowing you to swap the positions . Remove the correct pins on the header if needed and plug that into
the connector add the wires according to the diagram in the Asus manual . I recieved what I needed with my Asus mobo and case but did not have a one peice connector. The power and reset were prewired with two pin connectors. Check at
Radio Shack. Good Luck
March 10, 2010 2:58:53 AM
Best answer selected by jimp1102.
m
l
