23" Monitor, 1920x1080 wont work?
Fiostech12
7
Hi, I have an ATI 4850 with 512mb, just picked up a new HP 23" widescreen 16:9 monitor with HDMI input. Using HDMI the desktop screen wont fit the 23" area... what gives?
Fiostech12
7
When its set to the max res. in windows 7 64 (it says recommended) 1920x1080 and its like 1.5inches of realestate around the monitor is unused.... strange
Fiostech12
7
Actually I am researching now and found someone with similar problem, they said to go into the ATI control panel and find Image Scaling???
Nawal_23d
45
hmmm !
u got any controls or anythin on ur monitor ?
lg monitors come with auto optimization ... they adjust it automatically..
if not...then try some controls (buttons) on ur monitor
if that same problem persists(black frame) u can ask ur retailer ! u just bought it right ?
Fiostech12
7
Well, been messing around with the settings, only thing i can get to look good is 1680x1050 @60hz.... maybe this is the max the 4850 can do??
Fiostech12
7
Found it!! ATI catalyst contron center, in advanced mode (this is version 9.9), go to desktops and displays, you'll see a picture on the bottom left with a monitor, right click on it, hit configure, this changes the menu and SCALING is an option, go to scaling. By moving the cursor in there to 0% overscan, This fixed the problem!!! Thanks guys
