Hello, everyone. I'm new to this forum, just joined in the morning. I have some PC problems, which are really eating my head off. OK, so, the problems are as follows:
Hmm, now, the first problem my PC has is of crashing regularly with a BSOD for me. The BSOD is almost always "DRIVER_IRQL_LESS_OR_NOT_EQUAL", with the occasional "MULTIPLE_IRP_COMPLETE_REQUESTS" Now, IDK the actual cause for this, but I think it's because of my modem driver. Whenever I isntall the modem driver on any PC, it always crashes the PC, at least once, but is limited to once per month or so in other PCs. My PC crashes regularly. Sometimes it goes on for days without crashing, and sometimes, it's 4 crashes in 15 minutes. IDK why it happens, since the modem is from the ISP and obviously, the driver shouldn't be buggy. Even if it is, I can't update the driver, because either the updater stops responding, or, if downloading the driver files, gives an error about the driver files not being available. It so sucks when it crashes with such frequency...
Second problem, which is the real irritation for now is that my modem keeps dis-connecting almost every 10 seconds. The thing is, if it stays idle, it automatically dis-connects (this is not the ISP dis-connecting me due to in-activity, it just dis-connects itself. On all other PCs, it stays connected even when idle, while on my PC, it dis-connects within 5-10 seconds of being idle.). It needs data transfer for connectivity sustenance. OK, I do keep sustenance by running and pausing BitTorrent downloads, which keep transmitting and 1-2 KB/S, though I'd like a solution. But recently, the problem has worsened. The modem suddenly stops sending any data, causing the receiving light to blink for 2 seconds or so, and dis-connecting. Never happens in any other PC, only in mine. It just stops sending data, for no reason whatsoever, and I have to constantly keep dis-connecting and re-connecting the USB data cable. It keeps dis-connecting within every 10 seconds or so, but it sometimes does stay on, eventually reverting to it's antics of dis-connecting every 5-10 seconds... Another thing is that the Net Connection (Local Area Connection 2 on my PC.) keeps dis-abling itself automatically. No amount of re-enabling it works, since if I try to do so, it gives an error that connection failed...Please help me before I go crazy and hammer my modem to pieces.
Third problem...My HDD is gone bad (or so, since ChkDsk doesn't solve problems now-a-days), even then, it does work normally, so not that bad. Still works good. The problem lies in maintaining it. I use Tune-Up Utilities and Diskeeper, and whenever I defragment my HDD or clean the registry, it gives the BSOD mentioned above. I thought defragmenting and cleaning registry was meant to be putting the PC to it's proper potential, which it doesn't...
Fourth problem...PC is gone real slow. Games like NFS Most Wanted and Underground 2, which work smooth after a re-format of Windows are gone slow. Even the Tune-Up Turbo Mode doesn't work. It does suck to play games slow.
Fifth problem...I chat using mIRC. Now many times, it keeps getting it's settings re-set. I have to always take the trouble of putting it's settings back in place, and you know how many settings it has. I also lose all the commands which are made by the right-click in a channel. It happens if my PC crashes, or, as it happened recently, when I re-started my PC normally.
Sixth problem...my PC takes forever to re-start. It does turn off sooner or later when doing a shut-down, but even if I set it to restart 2 hours ago, it's still be saying "Windows is shutting down". I always have to press the re-set button. It sucks to be waiting for a damn re-start.
Seventh and the last problem...Can someone living in Mumbai, India, tell me where (from which dealers, with their addresses and phone numbers) is the ATI Radeon 5970 available and at what price? I need it to play my games and so that I don't have to worry about another card for 3-4 years at least. Please do help me. And yea, among HDDs, which company is better, Hitachi, or Western Digital? I have had my WD HDD go bad in 2-3 years, while the Hitachi HDD, which I'm running on ventilators for now is the Hitachi, so I feel Hitachi is excellent, but your opinions are obviously honoured.
Thanks a lot in advance.
P.S. My PC specs are there in my Member Configuration, though I'd be glad to post anything you need and is not posted in the configuration list.
