Tom's Hardware > Forum > Homebuilt Systems > New System Build > problem monitor driver software
Forum Homebuilt Systems : New System Build - problem monitor driver software
i have lost the driver of my monitor dell E1909W. where i will get the driver. windows ask for the driver. my monitor is not working properly? i visited dell website but i can not get the driver.how i can fix the problem?
Message edited by wasik2647 on 09-09-2009 at 07:38:40 PM
Sponsored Links
To the best of my knowledge, you shouldn't need a driver for a monitor. According to the Dell website, the monitor is plug and play so should just be able to plug it in, adjust the resolution and away you go.
When you say the monitor isn't working what do you mean? bad resolution, flickering etc.?
If the resolution isn't set to 1440x900 then you'll typically find the image to be poor quality and perhaps flickery and out of focus.
If you can give more details eg, what OS, grpahics card, connector type (DVI/VGA) should hopefully be able to help solve the problem.
Reply to takenra
There are 511 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
