I have a Dell E510 Desktop with motherboard 0WG261 which has Chipset i945G/GZ.
I used PC Wizard and in the section of
Mainboard --> Chipset --> Northbridge Information -->RAM max. Support
Its showing DDR2 (667MHz). I checked my RAM combinations and found a bottleneck and I upgraded them and now all my 4 RAM slots are full with each containing 1GB memory capacity and supporting frequencies 200MHz, 266Mhz and 333Mhz. I even checked the latency timings of all the RAM chips and they all were the same.
When i completed my setup and again looked the running RAM frequency, i.e.
Mainboard --> Chipset --> Memory Information --> Frequency. it still says 266Mhz.
that means, memories are not functioning at 333Mhz.
Now the real problem is that the BIOS is updated and it doesn't provide user the settings to edit Memory frequencies.
Help me guys! Everything else is working perfectly
