Hey guys, my roomate has a Gateway 840GM, which has a blue LED front power switch. He turned his computer off while away for thnaksgiving, and now the computer won't turn on. The switch turns on the fans / spins up the hard drive, but the blue LED on the switch does not light up, and at the same time there is nothing on the monitor (nothing at all, says check signal), fans are defaulted to MAX speed. This has happened once before, and all he did was unplug it for an hour and plug it in and it worked fine. We unplugged all drives, accesories, PCI cards, and memory to no avail. Tried a different PSU, same thing. Only thing that is the same is the mobo and the PCU, and the power switch. Any ideas?? Thank you!
