Is there a way to power up my external hard drive without usb
Hello,
the problem im having is my wd tb exsternal hard drive i plug power in then usb before led light would come on and start blinking for about 3 to 4 seconds then computer would reconize it now blue light comes on but doesnot blink can feel movement on hard drive though so when i pull usb out if power plug is still in hardrive the light stays on can i use factory jumper settings with special plug to gain access to my data
2 answers Last reply
More about power external hard drive
  1. Usually it is the power adapter that fails external HDD's. You may have to tear it apart removed the HDD and place it in another enclosure. If its a 3.5cm hdd then put in in a computer and see that is still runs.
  2. dormantreign is spot on. Pull it out and either get a new enclosure, or run it directly in the computer.
Hard Drives Light USB External Hard Drive Storage
