Simple Case mod
Forum Homebuilt Systems : General Homebuilt - Simple Case mod
I have the Akasa gamer eclipse case and want to add to install a side case fan. What Drill do you recommend I buy/use?
I was thinking Drimmel?
http://www.diy.com/diy/jsp/bq/nav. [...] earch=true
This will most likely be my only case mod ever, so nothing expensive and nothing too fancy, possibly just make hole for fan and its fittings (screws)
Message edited by Boxa786 on 09-10-2009 at 12:32:31 AM
Sponsored Links
Dremels are great. I would get one just to have one, they come in handy for many things. The other bits will help to round off edges in your case. Def. a good buy.
Reply to festerovic
- 0 +
Nevermind, I found that I can use a Dremel 300 kit, and a youtube video explaining it, also will need some low adhesive tape aka asking tape, and some files.
Reply to Boxa786
- 0 +
Sorry didnt see your reply, for some reason it didnt display it,
Yes found this
http://www.themodnation-forums.com [...] f=33&t=110
Looks like he knows what he's doing, and I found one on ebay with full accesories (cutting tools etc) for £33
Will also need some low adhesive tape such as masking tape, that I will get from a local diy (or maybe ebay it)
Reply to Boxa786
Good luck. Maybe take pics and write a tutorial on it...
Reply to festerovic
- 0 +
Thanks, was thinking the same, with video. See how it goes, would be good excuse to and top exhaust fan and maybe, window the remaining side panel with lights later. This is good and bad, good - do what i want, when and how i want, bad - time and money, :)
Reply to Boxa786
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Simple Case mod
There are 880 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
