Solved
PSU Power Dilemma
Got the Antec EarthWatts EA650 650W for $60 ( $40 after MIR ) http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015.
Had an impulse buy of PNY XLR8 VCG98GTEE1XEB GeForce 9800 GT 1GB for $100 ( $80 after MIR ) http://www.newegg.com/Product/Product.aspx?Item=N82E16814133304
Note the ratings given in the specification tab : "A minimum 400W or greater system power supply (with a minimum 12V current rating of 26A)"
The above PSU is spec'ed @ 25A whereas the card wants "(with a minimum 12V current rating of 26A)"
The PSU has 3 "independent rails" : +12V1@22A, +12V2@22A, +12V3@25A
Any suggestions EXCEPT ( maybe? ) changing the PSU :-) ?
Like patching cables? Crossing Fingers? :-)
6 answers Last reply Best Answer
More about power dilemma
  1. You will be absolutely fine.
  2. I would also like to know that wont the current be a problem? I can safely say that wattage wise the PSU is fine for a 9800GT, somewhat of an overkill.
  3. Generally speaking if a power supply is advertised as having mutiple +12 volt rails you can add the individual rails to get a rough approximation of the total current (amps). The total will not be exact. It will usually be a little less. High quality power supplies will come very close to the combined total. Low quality psu's will have a lower total.
    The vast majority of power supplies advertised as having mutiple +12 volt rails do not have true separate rails. They have only one large rail. Think of them as having "virtual rails". The advertising gurus really stretched the truth. Big stink over that a few years ago. There are a few power supplies that really do have separate rails. They are usually high end, high wattage models
    For the typical user and the typical gamer single and multiple rails are not an issue.
    Here is a link to an outstanding article by jonnyguru that explains multiple rails:
    http://www.jonnyguru.com/forums/showthread.php?t=3990
  4. If I remember correctly, jonnyguru had a review of the VERY SAME PSU and they did conclude that the rails were independent and not shared.
    @bige420 - are you suggesting that the manufacturer has quoted too high a value and it will never actually reach that requirement of "minimum 26A"?
  5. Best answer
    Usually, the manufacturer of the GPU recomend the PSU with a system configuration like this:
    Core 2 Quad extreme to full load, Velociraptor, GPU to full load, RAM to full load....
    Some moths ago, I install my X4 955, a GTX260, 2x500GB Itachi, DVD-RW,CD-RW, 4GB Crucial Ballistix Tracer and a case computer with 3 fans....all this with a 500W PSU Thermaltake, so, your current PSU is more that enough for the system.
    The 26 amps is the total recommended system rating. According to this, you have plenty of power
    Forgive me, but that a common mistake. That's 69 amps for a total of 828 watts. :lol: Look at the second line on the PSU label, the one that says max 12 volt power is 540 Watts - 45 amps.
Power Supplies Power Components Product
