Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > [Solved] 42 inch vs 23 inch display. graphics power.
Forum Graphic & Displays : Graphics Cards - [Solved] 42 inch vs 23 inch display. graphics power.
Best answer from FallenSniper.
Is playing games on a 23 inch 1920x1080 vs my 42 inch lcd tv 1080p the same demand on my system. Got a 5870 and i want to use it to play games in my 42 inch want to know if the resolution is the same then the demand from the card is the same.
Yes it is the same. The pixels are just bigger on your TV
Sponsored Links
Best answer
Reply to FallenSniper
Alright thanks was worried that going to my 42 might make my games run worse.
Reply to deathmustard
There are 919 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
