I installed a wireless card in my computer, but it somehow doesn't work. I don't really know much about computers (friend built this one for me), so what I need to know is:
1. Do I need a different wireless card, or is this one sufficient and I'm just having technical difficulty?
2. If the wireless card is not compatible or is not the fastest one available, which card should I buy?
My system is:
1. Intel Core i7-920
2. Diamond Radeon HD5970
3. Patriot DDR3 6GB 1333MHz Tri Channel
4. Gigabyte GA-EX58-UD3R
5. Corsair CMPSU-650TX- 650W
6. WD 750GB Serial ATA/300HD, 32 MB buffer
7. Cooler Master HAF 932
8. Lite-On 24X SATA DVD-RW Gen II
9. Netgear WG311 G PCI 54 Mbps Wireless-G PCI Adapter
10. Windows 7 Home Premium
Thanks for your time!
My system is:
