Hi, I have a question about how to speed up the processing of a software. I don't know if it's more important the CPU, the GPU or the RAM.
The software is Photomodeler, which is devoted to generate 3D models searching the same coded targets or patterns in two or more photographs.
I need to speed up that search. What that process does is go throw each image searching the coded targets or patterns.
I have to buy a computer that speeds up that search and I don't know if it's better to buy a powerfull CPU (such as Intel i7 with 4 cores), a powerfull GPU or a lot of RAM memory.
Thank you in advance!
Lisa
Lisa
