Let me ask this. I have both the DVD and HD connected to the bright orange SATA connections on the motherboard. Should they both be connected to the same bank of connections or at all? I saw a little sticker on those connections(SATA 0 and 1) and I think it has something on there about RAID. I don't have the board in front of me at the moment and I'm trying to download the manual on a very slow connection at work.ing
Message edited by mbarr69 on 09-11-2009 at 12:44:35 AM
Yes, it can make a difference. I'm guessing you have them plugged into the RAID connectors on the board. I would reconnect them to the other SATA connectors (normally, I've seen them as the black ones)
Moving the connection to the other ports got it working and let me tell you this machine is screaming. I kind of rushed through building this system for my friend. I figured they(the motherboard man.) were helping me out by making the ports to connect your primary and secondary drives to ports 0 and 1 on the orange set but there are other ports labeled 0 and 1. I just over looked them. OOOOPS! My bad. Thanks for your help guys. I feel like an idiot. ; )
