Sign-in / Sign-up
Solved
Can my computer use this power supply?
  • Power Supplies
  • Computer
  • Components
  • Product
Last response: in Components
November 30, 2009 4:04:02 PM
Hi,
Total noob here. I was wondering if anyone could help me out. I'm trying to upgrade my power supply and don't know what's compatible. I have an HP Pavilion a1610n with the standard specs except I have the 4200+ dual core with 4 GB of RAM and an nVidia 6600 video card. The standard specs are here:
http://h10025.www1.hp.com/ewfrf/wc [...] ct=3239117
I was looking at this one:
http://www.ncix.com/products/index.php?sku=35456&promoi...
If anyone knows if this power supply will work with my computer I would greatly appreciate it as it is on sale only through today.
Thanks,
Mark
More about : computer power supply
a c 246 ) Power supply
November 30, 2009 4:16:56 PM
Why do you want a 700 watt power supply? What are you going to do with your pc? Are you going to install two video cards and run them in dual mode?
m
l
November 30, 2009 4:18:42 PM
No just upgrade my current card. But the price is really good.
Thanks,
Mark
m
l
a b ) Power supply
November 30, 2009 4:19:30 PM
yea it will work, and it should fit fine since the case uses standard PSU's....
Is there a reason you need to upgrade the PSU?
m
l
November 30, 2009 4:25:48 PM
Yes, I'm upgrading my video card and the standard one isn't powerful enough.
m
l
Best solution
a b ) Power supply
November 30, 2009 4:39:22 PM
yea you are fine, just make sure you hide as many cables as you can.... the better the cable management the better for your overall temps....
November 30, 2009 5:02:32 PM
Great! I ordered it (there were only 9 left). Thanks for the advice about the cables. I will do what you have suggested. Thank you so much for your help!
Mark
m
l
a b ) Power supply
November 30, 2009 5:08:24 PM
my pleasure =)
m
l
