Sign-in / Sign-up
Solved
Will i have problems with this motherboard
  • Motherboards
  • Computer
  • Build
February 28, 2010 1:15:04 AM
So i read in the reveiws that in order to get the processor i want to get i need another am3 cpu to update it does any one know if this has been fixed?
Also here is the build for a gameing computer do you think this is a good build or a bad one? second time makeing a computer :/
cpu
motherboard
ram
case
Power supply
vid card
hdd
More about : problems motherboard
a b V Motherboard
February 28, 2010 2:04:50 AM
Get a hx750/850 and save yourself alot of cash, 1200 watts is way overkill
Get a 5870 not a gtx285, theyre old and slow compared to the 5870.
Get a spinpoint f3 or barracuda 7200.12, theyre way cheaper and perform around the same anyway
Other then that it looks good
m
l
February 28, 2010 12:08:29 PM
thanks will do but do you any idea about the mobo and the cpu? cause in the receiw cause i read in the reviews that there was a problem and it would eventually be fixed just wanna know if its fixed yet
m
l
March 7, 2010 11:18:47 PM
Best answer selected by filipebow.
m
l
