Closed Solved
What do case fans connect to?
I want to get a HAF 922 but i was wondering if i could connect these fans to something?
Does it connect to the tons of molex 4 pin thingies from the PSU? or to something on the mobo?
Thanks
3 answers Last reply Best Answer
More about what case fans connect
  1. either one, however only one of them not both together
  2. Best answer
    The small 3 pin connectors connect directly to the motherboard (or fan controller if you have one). The larger 4 pin (female) molex connectors connect to the (what else) 4 pin (male) molex connectors from the PSU. These are either or, never both (unless the manual suggests otherwise).
  3. Best answer selected by banned_03.
Heatsinks Connection Cases Overclocking
