Help choosing
Need a motherboard for 200 dollars or less for my i5-750 (LGA 1156). The motherboard needs to be compatible with 1600 ram and the easier the overclocking the better. Thanks
edit: for gaming build, SLI and crossfire NOT necessary (wouldnt hurt though)
4 answers Last reply
More about help choosing
  1. Are you planning to OC?
  2. yea nothing too drastic I heard reaching 3.4 is easy on stock values, so in that range 3.6 if possible
  3. Do you have any interest in the 'new' USB 3.0 / SATA 3 solutions? If so that'll narrow down your selection to Asus or Gigabyte. You can read more about that here: http://www.tomshardware.com/reviews/usb-3.0-performance,2490.html
    Have you given this a read?: http://www.tomshardware.com/reviews/lga-1156-motherboard,2463.html
  4. Or if you want to save a little $$ this may be of interest: http://www.tomshardware.com/reviews/budget-p55-motherboard,2436.html
Motherboards
