Archived from groups: alt.games.the-sims (
More info?)
"Maxon" <jen.magson@NOSPAMntlworld.com> wrote in message
news:TNjQe.2444$h4.1053@newsfe4-win.ntli.net...
> Um, why have you put the zips in your Downloads folder? You need to get
> the
> stuff out of your zips - the game doesn't read zip files.
Sorry, guess I wasn't clear about that. I don't have the zips in my
Downloads folder. I have them in a folder on my desktop that I download to.
I download any new walls to a folder labeled Walls and then inside that I
have a folder called Installed. After unzipping and installing the files I
move the zips to the Installed folder until I have time to burn them to a
disk since I like to keep the original files.
The only thing in my downloads folder is .package files.
> I don't know why the package installer is not putting the files in your
> Downloads folder. Are you sure you are looking in the right place?
> However, bear in mind, when you first unpack a wall or floor files with
> the
> installer programme, the file first goes into the Teleport folder so you
> won't see it in Downloads straight away. Once you start the game up, or
> Homecrafter or Bodyshop, the file gets put into the game by being
> transferred across to the Downloads folder then. I think this is to allow
> some basic file-checking against files already in the game. Using the
> self-installer means your files get given a stupid name made up of letters
> and numbers, so it can be very hard to work out what they are.
Thanks, this is a lot of help. I didn't know about the Teleport folder. I
did notice that there are a lot of files in my Downloads folder that are
just a bunch of weird numbers (about 1,000 of them in fact) so maybe these
are my wall files that I can't locate.
> The right place for your Downloads folder is:
> My Documents\EA Games\The Sims 2\Downloads
> The only files you should have in there are package files. Everything
> else
> needs to come out as it'll slow your game down. Put them in another
> folder - if you are unsure about using explorer, put the folder on your
> desktop.
> Best wishes
> maxon
> "glas" <glasgurl@earthlink.net> wrote in message
> news:rajQe.3070$9i4.2738@newsread2.news.atl.earthlink.net...
>> I've downloaded a lot of wallpapers and floors for my game and install
> them
>> as soon as I download. How come my folder of installed wallpapers has
>> over
>> 1,000 zips but my downloads folder only has bout 150 walls in it?
>> I've searched everywhere on my hard drive for the .package files but they
>> are nowhere to be found. I've also tried reinstalling the files and the
>> Package Installer pops up and tells me they are installing and then I go
>> look in my download folder and the files are not there.
>> Anyone have any ideas?
>> Thanx in advance, chrissy
