When running a T9900 in a laptop on battery, the power draw is 'relatively' constant, making the drain relatively constant (assuming no DVD is read and SSD is in place). This - I guess - is better for the life expectancy of the battery.
When running a i7 850QM with Turbo Boost Technology, the power draw is less constant, given cores are switched on/off (using same assumptions as before). This - I guess - is not in favor of the battery life expectancy, right?
So when selecting between a T9900 (or T9600) and a Core i7 850QM ... which would be the better choice??
P.S. - By battery life expectancy, I refer to the number of times one can recharge the battery, NOT how long the battery lasts on 1 charge (on average).
