hey, whats up everyone. I just need help finding a good CPU heatsink and fan cooler that would fit my case and do the job right. I have an AMD Phenom II x4 965BE overclocked to about 3.9ghz and just want to make sure that it keeps cool.
here are my specs:
Cooler Master HAF922 (so you guys know about how much room I have)
Asus Sabertooth 990FX
AMD Phenom II x4 965BE 3.4ghz (oc 3.9ghz) with stock cooler...
I have about 5 case fans.
2x200mm fans (1-top exhaust, 1-front intake)
3x120mm fans (2-side-intake, 1 chassis fan)
the 2 side intake fans are one of the main reasons why i came on this forum to ask which cooler you guys think is best for my setup. don't know if I should get something like the Cooler Master Vortex Plus or the Hyper 212 Evo or should i consider one of the Corsair Water Coolers?
i'm also afraid that the Hyper 212 Evo and coolers similar to it won't fit in my case...
HELP!
here are my specs:
HELP!
