HELP PLEASE, HELP
Forum Graphic & Displays : Graphics Cards - HELP PLEASE, HELP
My His Radeon 512mb 3650 AGP graphics wont work on my windows 7. I've installed drivers. But when i restart i it keeps shutting down and i have to do a system restore. Some 1 help.
Sponsored Links
Shouldn't Windows 7 have stopped working by now?
If you're still using beta that could be the problem.
Reply to SevenVirtues
no mines still activated its the RTC
Reply to petspaps
i dunno y its is but i only installed it a week ago. Help would be lovely appreciated.
Reply to petspaps
anyone please
Reply to petspaps
- 0 +
Do you have an onboard graphics you can test it with? Or another card?
Reply to jennyh
You try formatting your drive? Maybe a bad OS install..?
Reply to shadow187
No, it was a clean install. My previous card was a nforce mcp. Because that didnt work i had to get this one. Im really outa ideas and nothing i do is working.
Reply to petspaps
I'm loving that people are contributing. More Info. Phoenix Award Bios, AMD Anthlon xp 2500+, 1 gig ram. Previous card a Nforce 2 MPC that was fine until window 7 regected it.
Reply to petspaps
You need to conribute more yourself.
So, your original graphics card worked fine until you installed Windows 7?
So then you got a new 3650, installed it, and it doesn't work?
Give us the correct sequence. And give us full system specs including make/model if prebuilt. In either case, what size psu do you have? And how old is the system?
Reply to Twoboxer
ok. Mine is a Nvidia System, AWRDACPI MOBO, Phoenix Award Bios. It it has an inbuilt Nforce 2 MCP. 1 gig of ram. AMD Athlon XP 2500+ CPU.
Once i installed windows 7, it didn't recognize the inbuilt NForce. After investigating o found that there were no drivers to be found.
So instead i got a His Radeon 512mb 3650 AGP graphics card. Every time i try to install a driver for it, and then restart my computer, Windows fails to load. The computer reboots and i have to use system restore to load windows again.
Reply to petspaps
the system isnt that old i got it 2006. And the volts r 500 w
Reply to petspaps
Have you disabled (if required) the Onboard VGA via BIOS?
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
no ill try that, how should that help but?
Reply to petspaps
nope nothing.
Reply to petspaps
When it does a sytem check, it says the drivers are bad. But im using the same thing everyone else is using so......
Reply to petspaps
My AGP adapter i x4,x8 1.5 volts. And im also using the vga>dvi connecter.
Reply to petspaps
Maybe has anyone else had a similar problem?
Reply to petspaps
- 0 +
Ok wait.
Your mobo drivers probably aren't installed. You need to go to your mobo website, download everything from there and see how it goes.
Reply to jennyh
S-S-S-SEXTUPLE POST
You will also need your graphics drivers to be installed properly.
http://ati.amd.com/support/driver.HTML
Reply to djcoolmasterx
but see im not sure which drvers to install, as they are for xp. and ive already tried those drivers.
my mobo is msi k777
Reply to petspaps
- 0 +
Go into your control panel/device manager and see if you have any yellow exclamation marks for problem devices. I'm thinking you probably have a bunch of them because your nforce drivers aren't installed.
I've never heard of an msi k777, is that really the motherboard model?
Reply to jennyh
yer, it is. i was actually able to instal the major ones, like audio but just the graphics was unable to.
Reply to petspaps
I know this is a very unusual problem, aswell. My Bios is upto date aswell.
Reply to petspaps
ok. For now im using my external hard drive to install win xp and see if i can make it work there.
Reply to petspaps
Your computer is OLD, i would keep windows 7 WELL away from it, unless u like slideshows.
Your 1gig memory will be hogged by the O/S alone.
Revert back to XP....it'll be alot more quicker and stable.
However, if you wish to ignore that, Are you sure u have the correct driver for the correct card for the correct O/S?????
------------------------------ M2n32 SLi Delux | AMD pheonom 9850 @2.9GHz@1.3125v | 4x1gb OCZ SLi Ram @828MHz 4-4-4-12 Ganged | 2x8800 GTS 640mb@ 648\992 | 1x Maxtor 16mb 250Gb,
1x WD Caviar black 32mb 500gb | Onboard Sound | OCZGameXtreme 600W | ThermalTake Soprano
Reply to smoggy12345
Well theres your problem right there....Since Windows 7 isnt 'official' yet i doubt ATI will have stable drivers especially for older hardware.
Well thats what i thought so i have reverted it for the time being untill i get some more ram.
Reply to petspaps
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > HELP PLEASE, HELP
There are 523 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
