hunter315 Champion May 12, 2009 10,653 3 51,960 Dec 4, 2009 #2 How many times does it beep? What fashion does it beep in? Post your full system specs please, and if you have your motherboard manual find the section where it tells you what the beep codes are, that should help you isolate your problem. Upvote 0 Downvote
M megamanx00 Splendid Sep 3, 2008 8,216 2 31,465 Dec 4, 2009 #3 ^+1 Beep codes are there for a reason. Upvote 0 Downvote
JackNaylorPE Titan BANNED Oct 30, 2004 32,255 14 99,960 Dec 4, 2009 #4 Beep Codes are explained in your MoBo manual. Upvote 0 Downvote
huron Distinguished Jun 4, 2007 2,420 0 19,860 Dec 4, 2009 #5 Agreed...you could check your manual, or use google to find the beep codes for you mobo. Actually, beep codes could save you a ton of time - less troubleshooting to do. Upvote 0 Downvote
