Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] NEWBIE,,,NEED HELP ON POWER SUPPLY AND MOBO COMBO
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] NEWBIE,,,NEED HELP ON POWER SUPPLY AND MOBO COMBO
Best answer from JohnnyLucky.
I hope im at the right category if the forum
Hello all,
This is my first build so bare with me
I have a KINGWIN Mach 1 ABT-800MA1S 800W ATX psu
with a Asus P7p55d mobo
can someone please tell me i got the correct PSU
no where in the manual does it say
24-pin EATX12V , 8-PIN EATX12V Which is what my mobo needs
it does have
EPS12V/ BTX motherboard power connector (20+4pin)
EPS +12V POWER CONNECTOR (8 PIN) FOR INTEL 945/955 CHIPSET
+12V POWER CONNECTOR (4 PIN) FOR ATX/BTX
Even tho when i ordered it i asked customer service and they said it did,
I just want to make sure and double check ,cos when Im in doubt I ask,
these are links wit the specs
http://kingwin.com/products/cate/p [...] 00MA1S.asp
http://usa.asus.com/product.aspx?P [...] templete=2
last thing i want to do is fry everything!
thanks
Reply to remixer31
Best answer
You'll be fine. The power supply comes with the correct power cables for your motherboard.
The main power connector on a motherboard requires either a 20 pin or 24 pin psu power cable. The power supply comes with a 20+4 pin power cable that can be used as either a 20 pin or 24 pin connection. No problem.
The smaller power connector on a motherboard requires either a 4 pin or 8 pin psu power cable. Your psu has both so you're covered either way.
The manufacturer has the moherboard power options covered. :)
Reply to JohnnyLucky
Thanks a million , I wasnt to sure since i saw it said EPS, that was the only thing stopping me from connecting it and pushing the button
its about 12:50 am here now in NYC , i guess i wont get no sleep tonight!
thanks again Johnny
Reply to remixer31
There are 2165 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Is my psu sufficient for my pc ?
By rolli59, 2 hours ago:
Yes it can! The only problem is the CM reputation not delivering promised power but you...
Best offers
Top experts
