I recently built a new computer and here is the spec.
CPU: AMD Phenom II x4 965 Black edition
Motherboard : Gigabyte ga-ma790gpt-ud3h
RAM: A-data Gaming series DDR 3 1600 RAM 2GB x 2 = 4GB
PSU: OCZ ModxStream Pro 700W ATX 12v V2.2
HDD: Hitachi Deskstar HD31000 1TB 7200 RPM
Case : In Win fanqua ATX mid tower case
LG DVD burner SATA Model
I got weird problems. This computer works perfectly fine without any problem unless I reboot it. Whether I play game or web surfing, it never gives me any crashes or errors, but if I reboot the computer, then it goes to Blue screen of Death and automatically restart it. I tried Memtest86+, and my memory didn’t have any errors on it. So I took the ram out from the board, and reinsert it. OK. It came back to normal now. Yes. Work perfectly fine again, but it goes to BSOD again every time I reboot it. I tried to change memory voltage from 1.50v to 1.60, 1.65, 1.75, etc, but it still have same problem.
Now all I can do is keep the computer running without reboot it, or reinsert the RAM every time I reboot the computer!
Is it possible memory problem? Or board problem? What should I do? Please help me!
Thank you!
Thank you!
