G
Guest
Guest
Hello, so I might be water cooling my system (i5 2500k, gtx 580 with the possibility of adding a second) I have an Antec DF-85 case and I have some questions. The case has 2 140mm fans on the top, and 2 120mm on the back. What kind of radiator would work best? Would i have to get a 2x140 or could i get a 3x140 if it were to fit. I am looking for a very aesthetically pleasing system, so what brands ad websites should i be looking at? I found EK, and i really like their stuff but do they ship to US since they are in some other country?
ANd FINALLY:
part suggestions. Name any type of rad, pump, res, loop technique you think would be a good idea.
Thanks !
ANd FINALLY:
Thanks !
