My computer sometimes beeps 3 times (in this motherboard it means first 64K memory is possibly bad). However, I 've checked the memory and it's ok. I took the whole computer apart and tested the on/off switch and it goes on momentarily as it should and then goes back to infinite resistance. I also took the memory chips out and switched them and put them back in real good and I cleaned some ugly dust off one of them.
Now the computer boots fine without the 3 beeps, however, it goes on the moment I plug it in, which isn't what I want. I suspect that this behavior was also what it did before I took the computer apart (at least the last time I tried the computer). So what I have is the 3 beeps is gone (which is nice since the computer works now and boots to the OS fine) but I have a power on/off problem. I have to plug/unplug which isn't nice. I don't think the switch is stuck. I'm just looking for some odds on this?
1) Switch problem - doubt it.
2) Some internal latch that detects switch on/off. My motherboard is one of those hold for 4 seconds to turn off types. They have a lot of features nowadays with latch chips - sleep, hibernation ,etc.. I'm fairly sure that my switch is the momentary click on/off, not the old AT type since they actually go in, then come back out the 2nd push. This is the momentary-click type.
So is this an electronics problem? I guess it's hard to tell. I need to check the bios codes but I doubt the bios would care how I turn the computer on - by switch or by cord.
I doubt I miswired the computer but I guess I'll check that the wiring is ok.
Any ideas appreciated but it's ok to wait until I check the wiring again. I doubt it's that.
Thanks.
Thanks.
