Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Building New System
Building New System
Forum Systems : New Build Building New System
Hi, i've come to the decision to replace my terrible computer.
I have a budget of around £300.
I want the best i can get for that money.
I will be using it for gaming purposes such as AION and World of Warcraft.
I know my budget isn't to high but that's all i can afford currently.
I'm asking you to build me a computer for around that money!
I'm a UK resident if that affects anything.
As a start i've found http://www.cyberpowersystem.co.uk/ [...] m_builder/
Not sure if that's any good?
Thanks all,i welcome your input.
Reply to beanymattd
I don't require a mouse, monitor or keyboard.
I currently am running 1280x960.
I don't mind websites as long as they can ship to the UK, so preferably UK based websites since shipment will be cheaper.
Reply to beanymattd
Western Digital WD5000AAKS 500GB SATAII 7200RPM 16MB Cache -
http://www.ebuyer.com/product/124228
LG GH22NS50 22x SATA DVD±RW Dual Layer & RAM
http://www.ebuyer.com/product/169683
Kingston 2GB (2x1GB) DDR2 800MHz/PC2-6400
http://www.ebuyer.com/product/129177
SunBeam Freezing Storm Black Case - No PSU
http://www.ebuyer.com/product/150298
AMD Athlon X2 240 2.8GHz Socket AM3 2MB Cache
http://www.ebuyer.com/product/168971
PowerColor HD 4670 PCS 1GB DDR3 DVI VGA HDMI
http://www.ebuyer.com/product/173208
ASUS M4A78 770 Socket AM2+ 8 channel audio ATX
http://www.ebuyer.com/product/167128
Enermax Pro82+ 425W PSU - 82+% Efficiency Certified, 2x PCI-E, ATX12V v2.3
http://www.ebuyer.com/product/144083 all for £308
Message edited by obsidian86 on 09-15-2009 at 08:13:20 PM
------------------------------ When in rome ..
Reply to obsidian86
- 0 +
Do you need an OS? That alone costs almost £90 so it'll be very hard to get a decent gaming rig if you dont have one already.
Reply to build
i don't need an OS as stated above.
Reply to beanymattd
Build's question was valid. You never mentioned that you didn't need an OS.
Reply to shortstuff_mt
ah sorry yeh just realised!
:o
Would that build be better than http://www.cyberpowersystem.co.uk/ [...] m_builder/
Message edited by beanymattd on 09-15-2009 at 09:06:34 PM
Reply to beanymattd
Yes, the build above is better than that Cyberpower sytem. Notice the description on the PSU "STANDARD CASE POWER SUPPLY ***No OverClocking Possible***". That's NEVER a good sign. You would be much better off building your own so you can ensure all the parts are high-quality components. You never want to scrimp on the PSU.
bigger hdd bit better graphics card better power supply i would have to say better case
Message edited by obsidian86 on 09-15-2009 at 09:13:42 PM
Reply to obsidian86
ok thanks obsidian for your help.
I will wait for other peoples replies before i make my order.
Also i was looking to probably upgrade to 4GB RAM Instead of the 2 GB you have suggested.
Message edited by beanymattd on 09-15-2009 at 09:23:32 PM
Reply to beanymattd
if you can sqeeze another 20 quid you could get this instead of the 4670 http://www.ebuyer.com/product/173741 or http://www.ebuyer.com/product/168023
Reply to obsidian86
yeh should be able to, which is better out of those? in your opinion
Reply to beanymattd
the 4850 would be a lil bit better
Reply to obsidian86
http://www.ebuyer.com/product/173170
£40.00 case psu
http://www.ebuyer.com/product/161001
£29.82 Mobo
http://www.ebuyer.com/product/145586
£50.00 CPU
http://www.ebuyer.com/product/143844
£44.00 Memory
£70.00 GPU
£32.60 HDD
http://www.ebuyer.com/product/173553
£17.00 dvd
How does that build rate compared to the one you suggested obsidian?
Message edited by beanymattd on 09-15-2009 at 10:20:52 PM
Reply to beanymattd
its not too bad but i dont trust any nvidia chipsets too many have died on me ,the graphics card might be restricted by a normal pci x16 slot,the newer amd cpu's are faster then previous generations at the same clock speed but not by much. i believe the case and power supply is the exact one used in the cyberpower system
Reply to obsidian86
ok thanks my main priority is your suggestion anyway
Reply to beanymattd
There are 2069 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$600 Budget Gaming Build - Advice Appreciated
By coffeecoffee, 2 hours ago:
Alright, your on the right track. There are a few changes I would like to make if I...
Best offers
Top experts
