Problems opening portable WD hard drive
Last response: in Storage
Hi Sata, & Welcome to Tom's Hardware!
Two things I'd do before going to a recovery utility.
Go into the BIOS and see if the removable drive is recognized there. Have to have the WD passport plugged in initially to do that.
If not, change the USB port, and the cable. If you have a choice use an external power block, or try a USB 3 port which can supply more power to the drive.
If you are trying it on a new computer, try it on the computer that it originally worked on. Also try it on a Win-XP computer if available.
Report back for next steps if needed.
Ask the community
