Advice on parts -- Gaming PC
I am building a gaming PC in the next week. My three main concerns are the Motherboard, Processor, RAM, and whether the three components will work together without any problems. I would like some advice or feedback on these main parts listed below, are they decent? I don't need to spend more money for a motherboard with "next gen tech" for upgradability, just something with current tech. I also would like an opinion on 1600mhz RAM vs 2000mhz RAM. How much performance gain will I get from the faster RAM? Is it unstable? I plan on either buying a 5850 for now, then swapping to a GTX 480 when they release.. or just buying a 5970 now..
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131403
ASUS P6TD Deluxe LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231247
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
Intel Core i7-930 2.8GHz 8MB L3 Cache LGA 1366
Thanks.
1 answer Last reply
More about advice parts gaming
  1. mobo :great
    ddr 3 :fine .
    and the 930 ok everything will work out of the box.
    wait until the 400's arrive then the 5000 series will have a price cut (it always happenS)
Asus Gaming RAM Motherboards Product
