Tom's Hardware > Forum > Homebuilt Systems > New System Build > $700 new system build
Forum Homebuilt Systems : New System Build - $700 new system build
I haven't built a computer since 2004 and now I am in need of a new computer cause my last one completely gave out on me. I'v been reading a lot expecially on tomsguide.com and have been able to pick up a lot of valuable info. But just so I don't make any mistakes, I thought I would see what you guys think.
I just need some opinions or suggestions.
I don't need anything else except for these unless you guys think I might need something else.
Video Card http://www.newegg.com/Product/Prod [...] 6814150394
Case http://www.newegg.com/Product/Prod [...] 6811119196
PSU http://www.newegg.com/Product/Prod [...] 6817339024
Memory http://www.newegg.com/Product/Prod [...] 6820231274
MoBo http://www.zipzoomfly.com/jsp/Prod [...] e=10010088
CPU http://www.zipzoomfly.com/jsp/Prod [...] e=10010530
Hard Drive http://www.zipzoomfly.com/jsp/Prod [...] e=10007194
The memory I'm not sure on since it had no reviews on Newegg.
The Motherboard. It has 1 PCI-E 2.0 x16 slot 1
PCI-E x8 slot and if I were to crossfire it would it run at x16 or x8?
Oh :o and by the way i know that newegg is out of stock on the video card. But i'm sure I can find elsewhere. :D
Oh yeah i'm missing a cd/dvd burner what do you guys suggest for that.
Thanks!
Sponsored Links
I forgot about my Monitor.
Monitor http://www.newegg.com/Product/Prod [...] 6824236052
I plan on building this within 2 weeks.
Reply to niyo
Do you need an o/s (Windows) included in your budget, and what is the intended use of your pc...gaming, surfing the internet, etc....
------------------------------ "God invented Google so you would stop asking stupid questions."
Reply to Why_Me
It will used for gaming and surfing the web mostly. I don't need an O/S.
My monitor will make it $900 build. Crap I'll just get that later.
Reply to niyo
http://www.newegg.com/Product/Comb [...] mbo.256266 <----here's a combo deal worth looking at.
To answer your question...two cards in that mobo would have them running at 8x and 8x
Reply to Why_Me
Does that make much of a difference? 8x and 8x vs 16x and 16x?
I can't find any kind of warranty information on the Video card you suggested.
Reply to niyo
I'm not sure what the warranty specs are on that card. As far as the bandwith for a dual vid card set up in that build...no it will not affect it with your resolution. You will be just fine.
Reply to Why_Me
Hey thanks a lot! I decided to go with the combo you suggested. Good savings there! Ohhh.. I found on another website that the warranty is 2 years.
thanks again!
Reply to niyo
There are 477 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
