I currently own a CiT 750W PSU dual 12v rails, with these specs - 3.3V 28A 5V 30A 12V(1) 20A 12V(2)20A -12V 0.3A 5Vsb 2.5A
Either this - http://www.play.com/PC/PCs/4-/8284366/CiT-Silent-Technology-750UB-750W-PSU-Power-Supply-Unit/Product.html
or this - http://www.play.com/PC/PCs/4-/8903144/CiT-750U-750W-PSU-Power-Supply-Unit-Gold/Product.html
I don't know much about PSU's, but I currently run a HD 2600XT 512 GDDR3, runs fine, no problems.
I'm either going to be (most likely) buying a GTX 260 216 or a HD 4890.
The PSU is SLI capable (just saying).
But will the 20Amps on each rail be fine?
and it only has 1 6Pin PCI-e connector, I would use a 4pin(s) molex to 6Pin PCI-e adapter connection for the other power connection on the GPU, but even if the amperage counts as 40Amps (both added together) for the 12V rails,
WILL IT WORK?!!!???!!!??!!!!
I don't want any of my new parts ruined of my gaming rig.
Asus P5Q Premium
2X2GB Crucial Ballistix Tracer RAM DDR2-800
Core 2 Quad Q6700 (probably upgrade later on)
and of course the GPU and PSU.
I hope it is capable of working.
Just thought since it was SLI capable and is 750W, they wouldn't expect you to use 2 low end NVidia GPU's (motherboard is CrossFire only, won't be using CF, unless I go ATi, in which case, I'll have to change PSU later on).
Asus P5Q Premium
