Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > [Solved] Help me to choose what graphic card fit best with p5kpl-am
Forum Graphic & Displays : Graphics Cards - [Solved] Help me to choose what graphic card fit best with p5kpl-am
Best answer from JofaMang.
hey guys, could u help me pls?
i wanna ask u what graphic cards fit my MB asus p5kpl-am best?
ati 4770 gddr5, nvidia 9600gt, 9800gt or perhaps 4670
since P5kpl-am pcie 1.0 i confused to choose best card to avoid bottleneck. btw my pc spec are :
asus p5kpl-am
E7300 2.667 Ghz
2 Gb ram x 1 vgen
corsair 450vx
hope u'd reply this as fast as possible.. Thanks a lot
sorry for my english
Yes, that card will have no problem running on PCI-E 1.0. Only the most robust cards absolutely require 2.0 for full performance.
All systems have "Bottlenecks". CPu and GPU are always playing a balancing act, CPU is more than fast enough to supply a GPU, and the CPU becomes the "bottleneck". In reality, it is not a negative thing, just a matter of fact. If a CPU is not slow enough to hamper the videocard, and the videocard is the "bottleneck". Again, not a bad thing, every system must go one way or another. Upgrade one, and the other becomes the limitting factor.
Don't worry about it too much, your dual core will match to the 4770 nicely.
Sponsored Links
Since you have a decent PSU, I would suggest the 4770, as it is the nicest card that you mentioned, and you have enough power to not limit yourself to a PCI_E powered card.
------------------------------ http://valid.canardpc.com/cache/banner/822692.png
PhIIx3 710 @3.55ghz/1.5v w/ Scythe Samurai Zz HSF-24/49c ~ 4gb OCZ Gold XTC 5-6-6-18 @1092mhz ~ Sapphire 4870 512MB (795/1025)
Reply to JofaMang
thnx for ur reply,, but is it ok to combine 4770 with pcie 1.0 motherboard? could it run at max performance? im afraid my rig could experience bottleneck bcos my cpu is only e7300
Reply to Kudabalap
Best answer
Reply to JofaMang
thnx dude. i've been searching the answer from website forum to another but i think ur answer is enlighten me somehow
Reply to Kudabalap
There are 548 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
