Gadget Gift Ideas For Everyone
Im building a new system and am currently looking for the best water cooling solution for the HAF 932. System spec = i7 920 Rampage II GENE GX58 2 GTx 275 sli 300GB velociRaptor and 2 x 1TB RAID 0 HDD Coolermaster HAF 932 I really need help in selecting the best water cooling for this system, preferably under £150. Thanks...
Try a swiftech kit, They recommend it here. Or do you need help installing it? , In that case we need to know the model then someone else would answer as I'm clueless to this (installing)
I should be sound installing it cheers. Thanks for the pointer, tht coolin looks perfic for what i need, Cheers again.
