Specifications •Bus interface: PCI Express® 2.0
•Memory Support: 512MB GDDR3/DDR2
•Memory Interface: 256 bit
•RAMDACs: 400 MHz
•Full Microsoft® DirectX® 10.1 Shader Model 4.1 support
•Dual-link DVI output supports 2560x1600 resolution display
•Superscalar unified shader architecture
•320 stream processing units
•128-bit floating point precision for all operations
•Dynamic Geometry Acceleration
•ATI CrossFireX™ Multi-GPU Technology
•ATI Avivo™ HD video and display technology
•HD audio controller with multi-channel (5.1) AC3 support
•Native HDMI
•Built for Microsoft® Windows Vista™
Specifications •Bus interface: PCI Express 2.0 Support
•Memory: 512MB GDDR3
•Core Clock: 700MHz
•Memory Clock: 2000MHz (1000MHz x 2)
•NVIDIA® unified architecture with GigaThread™ technology
•Full Microsoft® DirectX® 10 Shader Model 4.0 support
•16x full-screen anti-aliasing
•True 128-bit floating point high dynamic-range (HDR) lighting
•NVIDIA® Quantum Effects™ physics processing technology
•Dual Dual-link DVI outputs supports two 2560x1600 resolution displays
•NVIDIA® PureVideo™ HD technology
•OpenGL® 2.1 support
•NVIDIA ForceWare® Unified Driver Architecture (UDA)
•Certified for Microsoft® Windows Vista™
•NVIDIA® Lumenex™ Engine
•Dual 400MHz RAMDACs
•Discrete, Programmable Video Processor
•Hardware Decode Acceleration
•High-Quality Scaling
•Inverse Telecine (3:2 & 2:2 Pulldown Correction)
•Bad Edit Correction
•Integrated SD and HD TV Output
•Noise Reduction
•Edge Enhancement
•Dynamic Contrast Enhancement
•Dual Stream Decode Acceleration
•HDCP capable
•DisplayPort output supports a maximum of 10.8 Gbit/s data rate and 2560×1600 resolution
** Due to hardware limitation, the available options for multi-display configurations are: Dual Display: DVI + DVI / DVI + DisplayPort / DVI + HDMI / CRT(via DVI to VGA converter) + DVI or DisplayPort or HDMI
•RAMDACs: 400 MHz
•Native HDMI
•Core Clock: 700MHz
•Noise Reduction
•Edge Enhancement
•HDCP capable
