My friend told me that I should not buy a GTX 260 because it wouldnt support my monitor. With this problem in my head, he still said that not even a converter would help me get good graphics. I wanted to knw, I have a Core 2 Duo, 2 gig Ram (DDR 2), 19 inch LCD DELL, PCI-Express 16x. Will there be any problems installing and using this VGA <Nvidia GTX260> ? Will there be a heat problem because im not looking forward to overclock?
Message edited by ludakon1234567890 on 10-02-2009 at 06:10:13 PM
It should be fine. The E177FP is a 17" monitor though...
It's actually probably more of a card than you need. I'm assuming your using 1280x1024. You could get something a little cheaper probably and be fine. 4850 maybe. What are you going to be using it for?
Message edited by FallenSniper on 10-02-2009 at 06:47:41 PM
I knw...I told that dumbass but hes saying otherwise...Yeah ur ryt.. I'm using 1280x1024, looking forward to play games at good graphics..Maybe not the max...But as much as the eye sees it as "AWSOME!!"....lolzz....do you think the 260 GTX can give that? also i want to knw...Are my ram and them enuf to play GTA the new one in really good graphics?
With a 17" or 19" monitor using a resolution of 1280x1024, a GTX260 will max out any game in existence. (even Crysis to a degree).
You can comfortably play Crysis at Very High settings with AA turned to x4 or so. Everything else (COD4, COD5, GTA4, Fallout3, etc) and your graphics card won't even break a sweat.
