Howdy all,
I've hit a snag in my loop rebuild and since the important info was getting buried in my build log I figured I'd make a new thread to make it easier.
Only thing I changed was the GPU, pump housing and some QDC fittings (see progressive build timeline).
Loop before rebuild:
MCP655 + Koolance housing
360 + 120 rad
i5-2500K + EK Supreme HF Full Copper
2x6950 2GB + EK 6970 Nickel/Plexi Full Cover Blocks
Temps: 45C on both GPUs at load
Rebuild Attempt #1
MSI GTX 560Ti Hawk + Swiftech MCW82
Koolance V4N QDCs by GPU (to facilitate upgrades)
Pump got air in it and tended to "scream," so I ordered a Primochill Myriad dual bay res/top. Never got the computer running long enough to do anything with it (check temps, etc)
Rebuild Attempt #2
MCP655 + Primochill Myriad
QDCs still in the loop
Temps were at ~42C idle, and would spike or drastically increase with small uses of the GPU (literally just my changing background every 10 minutes). Eventually the temps would stabilize at 62C. Tried to test with Skyrim and computer shutdown due to overheating within 30 seconds of running the game.
Rebuild Attempt #3
Reseated the GPU Block, used MX-2 instead of Ceramique 2 TIM
Absolutely nothing changed from Attempt #2. Absolutely nothing...
Rebuild Attempt #3
Took out the QDCs (postulated to block the flow in loop)
Initial idle temps dropped to 38C, but same thermal spiking occurred and eventually leveled off again at 62C. Tested using Furmark to see what the temps were doing, and the temps spiked to 90C+ in under 5 seconds.
