New build wont boot- Please Help
Last response: in Systems
Specs-
Intel Core i5 750
EVGA 896-P3-1171-AR GeForce GTX 275
SILVERSTONE RAVEN RV02
G.SKILL Ripjaws Series 4GB
Sony Optiarc DVD Burner
Seagate Barracuda 7200.12 ST31000528AS
CORSAIR CMPSU-750TX 750W
COOLER MASTER Intel Core i5 & Intel Core i7 compatible RR-B10-212P-GP 120mm "heatpipe direct contact"
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel Motherboard
Everything went together easily. However, once I button it all up, plug it in, hit the power switch- NOTHING happens. Nothing turns on, no fans, not the hard drive, nothing. The only change is the boot LED on the mobo lights up green. I've checked everything 3 times and all of the connections are good. Any help with what might be causing this would be a HUGE help. Thanks
More about : build wont boot
Ask the community
