Tom's Hardware > Forum > Graphic & Displays > ATI > 4870 need for speed shift problemo
Forum Graphic & Displays : ATI - 4870 need for speed shift problemo
hey guys, i have just recently purchased a game need for speed shift and for some reson when playing on very high settings you can possibly get on the game without and anti-alising and anistroping filtering, it lags for some reason on my system, which i think is kinda wierd as it passes the recommended settings, anyway here is my specs CPU: intel core2quard q9300 (not overclocked)2.5ghz GPU: hd4870 512mb (not overclocked)and ati driver 9.9 Ram: 4gb Operating system: vista ultimate 64bit
Sponsored Links
What resolution are you running at? I've noticed Shift to be a pretty resource intensive game.
Reply to microterf
If you check the NFS boards, you'll find there's a lot of other ATI owners having the same problem. The game doesn't communicate with the video drivers as it's supposed to.
Add to that the Vette glitch, bouncing glitch, steering wheel glitch, input lag glitch... and you'll find that 'Shift' is the buggiest NFS game ever released.
------------------------------ <Gaming PC> | Cosmos 1000 Case | Zalman 850W PSU | EVGA X58 3XSLI | i7 920 OCed to 3.3GHz Stock Voltage/Fan | 6GB OCZ Platinum 1600 | Sapphire HD5870 | 2x Samsung 2343 (2048 x 1152) + 1x Samsung 2333HD (1080p) | 4x 1TB HDs in RAID 5 | Windows 7 Build 7100
Reply to Zirbmonkey
Yeh..... thanx for that...... i also did my own little research and i found out that it was mainly the ati cards that had the lag issue, so thanx for the heads up
Reply to thegunners
Ati is going to release a hotfix in order to resolve the fps issue with this game.
Reply to michaelmk86
There are 591 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
