Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > New to forum!! PLEASE ADVICE!! i5 build...
Forum Systems : New Build New to forum!! PLEASE ADVICE!! i5 build...
:hello: :hello: How you guys doing? I have been researching and lurking around here for awhile. I know most of you guys are pretty good at this stuff from all the advice and posts I had read. I am currently running a very old machine for 8 years now and it still works!! :o P4 2.6 ghz 512 ram 64 gpu. YES, for 8 years straight and i had went thru 4 hard drives.
As you can see i am in need of a new machine BUT i do not want to be spending a few g's. My budget would be under $1000 before MIR's. I want to use this machine for EVERYTHING that i had missed over the past 8 years. That goes for a lot of PC GAMING!! I want this PC to last me more then 5 years but i know that's not going to happen. I do want parts for future upgradeable. i am building an i5 system (parts are listed on the bottom) but for whatever reason you guys may have for not going with i5 but rather go with i7... PLEASE PLEASE LIST THEM AND TELL ME YOUR ADVICE.
Please point me to the right parts, price and the direction.
well enough for the blahblahblah and on to the good stuff.... here is a list of parts that i had arrange. please... please let me know what am i missing, need or if any of these parts are not compatible with each other or whatever not...
THANK YOU!!
APPROXIMATE PURCHASE DATE: At anytime when the price is right.
like microcenter is having the i5 for $159.99. i'll order that today!!
BUDGET RANGE: $1000 and under before MIR - if that's not possible with the parts i want then i could swing a few hundred more.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: GAMING, Internet, School, Light Photoshop, and whatever I throw at it.
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, I already have a antec 900 case
PREFERRED WEBSITE(S) FOR PARTS: Not really sure how many part sites are there but whoever got the best price/deals... newegg.com, microcenter, ewiz, tiger whatever.... ANYWHERE..
PARTS PREFERENCES: Intel, EVGA, whatever you guys recommend.
OVERCLOCKING: Maybe... I want to run stock first cause i am still learning how to OC...
SLI OR CROSSFIRE: SLI... Maybe.. if that happens it will be in the near future.. but for now, no
MONITOR RESOLUTION: Dell S2209W 1920x1080
ADDITIONAL COMMENTS: I would like a quiet PC, should i go for windows 7 or vista or ??? I am not going to OC until i figure out how to so if we could find a MB that's super easy for a first timer to OC would be sweet. I like EVGA... MB AND GPU please. And would my 900 case be big enough? Also i will be getting an dvd drive and another HDD later on. Shouldn't be more then $80 but that's after this build.
MB- $199.99 newegg
EVGA P55 SLI 132-LF-E655-KR LGA1156 Intel P55 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813188055
RAM- $89.99 newegg
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH - Retail
http://www.newegg.com/Product/Prod [...] 6820231276
MB and RAM COMBO DEAL - $269.89 newegg
http://www.newegg.com/Product/Comb [...] mbo.258612
GPU - $239.99 newegg
EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814130475
OS - $109.99 newegg
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders w/ Tech Guarantee - OEM
http://www.newegg.com/Product/Prod [...] 6832116677
GPU and OS COMBO DEAL - $339.98 with $15 MIR
http://www.newegg.com/Product/Comb [...] 14-130-475
Power Supply - $119.99 with $10 MIR newegg
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ... - Retail
http://www.newegg.com/Product/Prod [...] 6817139006
HDD - $49.99 newegg
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822152181
DVD BURNER - $35 ewiz with $5 off
Samsung SH-S223B
http://www.ewiz.com/detail.php?name=SHS223B_BE
CPU - Microcenter - $159.99
i5
http://www.microcenter.com/single_ [...] id=0317379
Arctic Silver 5 Thermal Compound - OEM -$6.99 + 2.99 shipping newegg
If anyone could find a cheaper price... PLEASE POST LINK!!
TOTAL - $979.91
TOTAL AFTER MIR - $954.91
THANKS!! :bounce:
Reply to lenjaiah
I would look to add a HSF, such as this one... http://www.newegg.com/Product/Prod [...] -_-Product
Everything else looks to me...
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
-Tecmo34
Thank you for your reply. Coming from you is a plus.
I see that the HSF you had recommend comes with thermal grease... would that be as good as the Arctic Silver 5?
Reply to lenjaiah
- 0 +
You are welcome...
I would stick with the Arctic Silver 5 (pick it up from Microcenter to save on delivery cost). Newegg doesn't list the type of thermal paste it is, so I'd just stick with what "we" know is one of the best.
Reply to tecmo34
Few questions i would like to ask...
1) would the parts i had arrange... would any like the cpu and gpu bottleneck? (all on stock settings)
2) would all of this fit the antec 900 case? along with HSF that Tecmo34 had recommend?
3) get a bigger or smaller PS... might be going SLI in the near future and also OC...
4) more then half of the people on this forum OC there cpu... from the list i had arrange... if i dont OC... it will still run as good as if i did OC?? (might be a stupid question.. i'm just wanna make sure)
5) if all parts are good... i would just put all of them together and power up and install OS and hopefully i would not run into any problems????
thank you
Reply to lenjaiah
- 0 +
1) I see nothing as a bottleneck in your system.
2) Everything will fit into the Antec 900.
3) If you plan to SLI, you are okay with the 750w PSU. It will handle two GTX275's just fine. If no SLI, you could drop down to a 650w or 550w PSU and be okay
4) You will be fine with your system, if you don't OC. Once you get setup, stop in the OCing section and they'll help you out. You should do 3.2 GHz or a little higher by just using the MOBO's dummie OC feature, which does the work for you. :)
5) That would be the plan... including installing all the drivers... You may have to go into your BIOS and manually adjust your RAM timings and voltage to spec. After getting up and running with everything installed, I recommend running Prime95 to make sure system is stable and not running too hot. 3DMark Vantage will give you a benchmark on your system performance, so you can compare to other similar systems.
Reply to tecmo34
thanks again Tecmo34!!
would you recommend me going with i7 instead of i5? Pretty much i want to used this computer for whatever the reason is. whatever i throw at it. I just want a stable computer that could last me for a long time. of course with a few minor upgrades from here and there. As you can see, we cant really keep up with technology... I just don't want to be stuck with the parts i have and when its time to upgrade.. minor will become major...
also... ram is good enough? or should i do better?
thanks
Reply to lenjaiah
- 0 +
The easy one... Your RAM is fine. You will notice very little difference between 1333 & 1600.
The hard one... I'm a fan of the Core i7 920. I still feel it is the best CPU/Setup you can buy. However, all results/benchmarks so the Core i5 performs very close to the i7 920. It really comes down to three things to me in one what Core ix to get.
1) You plan/do heavy level CAD, Video or Picture editing or activities along those lines. This type of system is best designed for the Core i7 920.
2) Plan on highend dual GPU setup or triple GPU setups, it is best suited for the Core i7
3) Want the best system for the money without spending a lot, this is what the Core i5 is designed for. You are looking at about another $200+ for an Core i7. If the benefits in your mind outway the cost, switch to the Core i7. At this point, I would recommend the Core i5 to you. It is the best bang for the buck performance wise (Sorry my AMD fans...)
Reply to tecmo34
thanks for breaking it down. that's just what i needed to hear!!
i5 it is!!
would you say this build is over priced? i mean there are a lot of cheaper parts but are these average or way over? whats your opinion on it?
Reply to lenjaiah
- 0 +
It is a great system at a good price!!!
You will enjoy your system and be amazed at how fast things open and work for you. I gave my Dad a Q9550 to replace his P4 and he couldn't believe the difference. He was clicking on icons and opening four or five sessions before he knew it. He was so use to having to wait or click on it a bunch of times with his P4.
As I said... Have fun with the build and if you have more questions... We are here to help!!
Reply to tecmo34
- 0 +
http://www.newegg.com/Product/Comb [...] mbo.257352 Combo Discount: -$10.00 Combo Price: $249.98 Free Shipping*
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel Motherboard - Retail
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-4GBRM - Retail
http://www.zipzoomfly.com/jsp/Prod [...] e=10006382 $99.99 Free Shipping
PC Power and Cooling SILENCER 750W QUAD S75CF Power Supply Retail
Message edited by Why_Me on 09-19-2009 at 09:39:36 PM
------------------------------ "God invented Google so you would stop asking stupid questions."
Reply to Why_Me
i have thought it over and dont see a good reason for me to go SLI... or am i missing something a SLI thought here?
if i am not going SLI... 650w would be good enough you say? i guess this PS would be as good?
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6817139005
i would want to stick with corsair.. but newegg has that PS sold out... i dont wanna pay taxes with microcenter. anyone know anywhere else i could get this for the same price without tax and free shipping?
Reply to lenjaiah
- 0 +
Here is the same deal... http://www.zipzoomfly.com/jsp/Prod [...] e=10007111 for the Corsair 650TX.
SLI is a way to boost your performance in gaming but it is not required. The GTX 275 will deliver good performance at your resolution without the need for two cards.
Reply to tecmo34
if i was to hook this up to 46" HDTV. would i need SLI? i am planning to stay with this LCD for awhile.. if i do SLI, do i need to upgrade? is there anything else i need to upgrade by going SLI?
Reply to lenjaiah
guys i found this...
http://windows7.digitalriver.com/s [...] 3584604406
$30 bucks for windows 7 home!!!
u must have a .EDU college address to get in....
i dont know if this is a full or what... but my questions is... what version do i need?
Reply to lenjaiah
There are 1912 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1400-1800 range, first build, need feedback
By Hopz, 3 hours ago:
I would keep the 750W for future upgrades and possible SLI in the future. Will save you...
Best offers
Top experts
