Tom's Hardware > Forum > Homebuilt Systems > New System Build > Boot problems on homebuilt system
Forum Homebuilt Systems : New System Build - Boot problems on homebuilt system
Hi Guys,
I'm currently trying to build a new PC (first time).
I was having problems booting, so I've breadboarded the system and removed all the components except for the Heat Sink/Fan, and CPU. On turning on I received a steady series of beeps, so I installed a RAM module and graphics cards. Everything seemed to be running fine then, I was getting a single beep indicating a successful POST.
However, when I tried to connect my case fans, it seemed like something shorted out, and now I can't power on at all and the power and reset lights on the motherboard are continuously flashing.
Can anyone suggest what the problem might be?
Thanks
Sponsored Links
Connect the case fans with a molex connector. They may be drawing too much power from the motherboard.
Reply to evongugg
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
