Tom's Hardware > Forum > Homebuilt Systems > New System Build > [New System Build] Suggestions?
Forum Homebuilt Systems : New System Build - [New System Build] Suggestions?
I'm ordering tonight.. just wondering if I picked the right stuff and if you have any suggestions. Also, if everything is compatible, thanks!
MB/CPU
http://www.newegg.com/Product/Comb [...] mbo.246589
gfx card/ram
http://www.newegg.com/Product/Comb [...] mbo.256536
hd/ 2 of these in raid 0
http://www.newegg.com/Product/Prod [...] 6822136359
psu
http://www.newegg.com/Product/Prod [...] 6817139006
dvd
http://www.newegg.com/Product/Prod [...] 6827151187
Any suggestions are welcome..
Sponsored Links
Why 2 greens? They are designed to be cool and low power with little regard to speed. Get 2 Samsung 500GB F3 drives, they will perform much better.
http://www.newegg.com/Product/Prod [...] F3%20500GB
The ram in this combo will perform better, it comes out to less before rebates but a bit more after
http://www.newegg.com/Product/Comb [...] mbo.256539
Reply to hunter315
Okay, I switched the ram/gfx combo for the one you said. Any suggestions on a WD hd instead? I don't like samsung.. ><
Reply to zi0n
if you want to go WD get a 640GB caviar black
http://www.newegg.com/Product/Prod [...] -_-Product
It will cost you more and will perform about the same as the F3
Reply to hunter315
There are 1166 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
