955 BE cooler + cabinet
Hi all....
I just bought the 955 BE. I will use it on Asus 785g(TD -EVO model). I just gathered info that the stock cooler is very noisy and not that good. So i short listed two air coolers the CM hyper 212+ and the CM hyper TX3.
In my area (Kolkata, India) the 212 costs around 2.3k while the TX3 1.3k INR. I am also looking forward to buy a good cabinet(bottom PSU mount).
If i buy the TX3 my budget can allow upto 2.6k within which i can get the NZXT gamma or CM 311plus etc.. but with 212+ my budget will allow 1.6-7k CM311.
I am using a HD6850 sapphire..
I do not intend to overclock at all now.. maybe when needed a max of 3.5ghz will do but where i live the room temperatures are quite high (above 30 C) in summer.
Please suggest any alternatives or the better choice of the above. thans in advance :) :)
1 answer Last reply
More about cooler cabinet
  1. Hi and welcome to Tom's forum.
    The Hyper 212+ is the best one of those two
Heatsinks Cooling Overclocking
