A typical PC water cooling system uses an air cooled radiator to dissipate the heat.
However, would it be possible to use a nearby lake's water to dissipate the heat? I live about 10 meters away from a 2-3 meters deep lake and it's right next to my backyard. I plan on using a closed loop system, none of the lake's water would enter the cooling system.
I'm not sure what would be the costs of running two tubes across the backyard, a pump that can handle the extra water and finding/building the radiators.
My main current concern is corrosion if I am going to build it. Copper is expensive, and building a radiator out of copper would burn my wallet. I'm tempted to use old aluminum or steel heating radiators (the heating system parts found in older houses), but I also want to use copper based water blocks. If I use aluminum, steel or copper with each other, they would corrode for sure. What to do?
Another concern is water pressure, but I have yet to decide on the thickness or diameter of the tubing, though it will be rubber or flexible plastic.
